Increase the output 2.5TD engine.
- janneh600
07 Feb. 2014 17:00
Hello everyone.
Have read that by replacing this rod in the fuel pump can raise the power of 2.5TD engine with about 20HP.
Someone on the forum who have tried this?
Many people in Sweden who have tried with positive results. :woohoo:
Antworten zu janneh600
- janneh600
Re: Increase the output 2.5TD engine.
07 Feb. 2014 18:20
Hallo Janne,
das Teil ist mir nicht bekannt. (Ich fahre aber auch keinen TD :evil: ) Ich weiß aber, das bei uns einige die Feder (Position 7) austauschen und damit ein höheres Drehmoment bekommen sollen. Möglicherweise hat dies den gleichen Effekt.
- janneh600
07 Feb. 2014 18:33 - 07 Feb. 2014 18:40
I can imagine that a rod of this type and a spring with less resistance can make a difference on a car without a turbo. Turbo is nice! :drive1:
Fuel curve is controlled by the # 4 and # 9.
Check this out www.306oc.co.uk/forum/showthread.php?tid=131&pid=90467
Letzte Änderung: 07 Feb. 2014 18:40 von janneh600.
- saviemeke
- janneh600
11 Feb. 2014 21:14 - 11 Feb. 2014 21:15janneh600 schrieb: I can imagine that a rod of this type and a spring with less resistance can make a difference on a car without a turbo. Turbo is nice! :drive1:
Obviously I mean #7 and #8. Not #4 and #9.
I have contacted a gentleman here in Sweden that manufactures custom parts.However, I have not received any reply from him yet.
Dem ser ut så här
:daumen2:
Letzte Änderung: 11 Feb. 2014 21:15 von janneh600.
- saviemeke
11 Feb. 2014 21:27
I am wondering what such a rod should cost, if they are still available.
Ich frage mich was so ein Stift Kosten sollten, wenn sie noch verfügbar sind.
Antworten zu saviemeke
- janneh600
11 Feb. 2014 21:43
Them in the picture cost 800sek (90eur)
Availability, I have not received any reply from him.
The same type of stick is also mounted in for example wolksvagen.
The stick is originally from Bosch VP pumps for industrial use.
- saviemeke
15 Feb. 2014 20:52
Hi,
a friend of mine pointed out to me on this ad on the Dutch market place
Marktplaats
I write them for more information, when I know more,i will write it here.
Marktplaats
- janneh600
16 Feb. 2014 08:19
Hello.
The stick is available here. www.autostable.se/motortrim/optimeringsl...ar/dt-piston-1833317 Very expensive unfortunately.. €370 :1435:
- janneh600
16 Feb. 2014 10:38 - 16 Feb. 2014 10:41
I've found a cheap stick..
www.brickwerks.co.uk/index.php/ve-boost-pin.html
But it looks just like the original. I'll make some calls tomorrow and sort this out.
Letzte Änderung: 16 Feb. 2014 10:41 von janneh600.
- janneh600
17 Feb. 2014 09:02
This stick can be ordered from
www.dieselmeken.se/
Cost 800sek (around €90)
Only works on a turbocharged engine.
More power to the Kult-Wohnmobil :daumen2:
- saviemeke
17 Feb. 2014 12:26 - 17 Feb. 2014 12:27
On the Dutch marktplace site this advertisement was found.
Marktplaats
I asked for more info, they asked for a new pin, including mounting 550€ :woohoo:
And they give teh advice to use a KN airfilter, cost 120€ :woohoo:
Marktplaats
Letzte Änderung: 17 Feb. 2014 12:27 von saviemeke.
- janneh600
- janneh600
17 Feb. 2014 19:29
If there is someone who wants to buy this stick. I can arrange it all. The freight on the stick if I buy it in Sweden is part of € 90. So there will be extra shipping to Germany or wherever you want sent ... It has the same function as DT piston. Maybe even better. And the price difference is huge.
:543: :1723:
:543: :1723:
Ladezeit der Seite: 0.425 Sekunden
