Body Repair
- Jankos
- Jankos
Re: Aw: Body Repair
14 Juni 2010 19:23Today I made some painting. It didn't go well at all. It looks good if you are far enough :1435:
Also I installed DRL (tagfahrlicht) and found nice place for those.
No more big needs before trip! Just washing and test drives. :drive1:
Family Koskinen from Jokioinen, Finland.
Photos of our motorhome
Antworten zu Jankos
- Jankos
Re: Aw: Body Repair
25 Aug. 2010 19:40
HELLO!
I find out what regulations are for a DRL lights!
ECE R87 is for independent light and ECE-R48 is specificating how these should work.
There is mention:
6.19.7.2. If the distance between the front direction-indicator lamp and the daytime running
lamp is equal or less than 40 mm, the electrical connections of the daytime
running lamp on the relevant side of the vehicle may be such that either:
(a) It is switched OFF; or
(b) Its luminous intensity is reduced during the entire period (both ON and OFF
cycle) of activation of a front direction-indicator lamp.
This is defining that on my installation case (and some others too) DRL must be shutdown when direction indication lamp is blinking.
So I must connect wire from direction indicator lamp with a diode to shutdown line and also add a diode to normal shutdown line.
With this connection I'm sure that blinking is easily seen...
There is mention:
Antworten zu Jankos
Re: Aw: Body Repair
25 Aug. 2010 20:16
Jankos schrieb:
what you find :evil:
In Germany, there ist no regulation for the distance between DRL lights and front direction-indicator lamp! Look here on page 94 you see the regulations for DRL lights. .. or here . And Germany is allso in the EU :evil:
Hallo Janni,6.19.7.2. If the distance between the front direction-indicator lamp and the daytime running
running lamp on the relevant side of the vehicle may be such that either:...
- Jankos
Re: Aw: Body Repair
25 Aug. 2010 20:32 - 25 Aug. 2010 20:35BTW, your regulation is revision 4, newest one is revision 7... There might be some changes
In english it's here www.unece.org/trans/main/wp29/wp29regs/r48r6e.pdf
Yes, I know it would take couple more years to find person who can translate this one from english to deutsch
Letzte Änderung: 25 Aug. 2010 20:35 von Jankos.
Antworten zu Jankos
Re: Aw: Body Repair
25 Aug. 2010 20:47
Jankos schrieb:
... and I think, there is a inventory protection for old vehicles :drive1:
it ist the official Version by the german traffic ministry :1563:BTW, your regulation is revision 4,
- Jankos
Re: Aw: Body Repair
At least you even got any version on your own language.
Here in Finland there is not any official or any unofficial information of DRL things. I have asked those things with inspectors and they are just saying that they don't know what is right solution with these.
Letzte Änderung: 25 Aug. 2010 21:00 von Jankos.
Antworten zu Jankos
