Help with electrical system problem
- checkmate
01 Juni 2015 22:33
:2172:
Hello!
We're having a problem with the electric system and hope somebody can help. The thing is for the last 5 days, at the end of the day the electric power seems to fail. The light goes on and off at moments and some hours later it works fine as usual. The convertor to 220V works perfectly.
Today the problem has been bigger, and we couldn't turn on the electric system because it turns on and off intermitently.
We've got two solar plaques and they seem to be working and loading correctly as we're having a lot of sun in here.
Any ideas of what the problem can be??
Thanks a lot for your help!
:daumen2:
Hello!
:daumen2:
Antworten zu checkmate
Re: Help with electrical system problem
01 Juni 2015 22:49
Hello Javi,
I think that the problem is in the wiring from the charging block (under the seat) to the BCC on the dashboard. ....or in the board of the BCC. Since probably only helps to take a diagram and measure. Look at the Pictures from the Electric too.
Folgende Benutzer bedankten sich: checkmate
- saviemeke
02 Juni 2015 21:36
Hallo Javi,
I think, the plug connectors between the wiring will give some problems. they can oxidize whereby the connection will lost.
Antworten zu saviemeke
