Improve charging system
- dsj1979
25 Aug. 2015 22:20
Hi,
My charging system is standard other than a citrix relay being added and a solar system installed. I have 3 solar panels which work brilliantly and are connected directly to the batteries; I have these as I'm unlikely to ever use shore power as I prefer wild camping instead of campsites!
The issue I currently have is the engine only provides about 5amps to the leisure batteries when running which isn't enough (especially as the microwave and toaster uses about 80 amps!
). Is there a simple way to increase the amps provided by the engine or am I best putting a new system in bypassing the current control panel and going straight to the battery? As the odds are I won't use shore power I'm happy with that part of the system, it's increasing the power from the engine side I want to do.
Many thanks,
Daniel
Many thanks,
Daniel
Antworten zu dsj1979
Re: Improve charging system
25 Aug. 2015 22:39Hallo Daniel,dsj1979 schrieb: Is there a simple way to increase the amps provided by the engine ...
look here.
